Hello, my Realdash dashboard sometimes flickers, the black screen comes and goes, I see it very momentarily, sometimes it does it constantly. It usually does it when changing music. I use YouTube Music. The screen was flickering more in Apple Music, why does it do this?
Hard to say, to flicker on entire screen like that seems more like a hardware issue than software.
It doesn’t flicker on all screens, only the .rd I made flickers
I I uploaded a video, you can check it out
It only vibrates on my multimedia, it does not vibrate on the pc or phone.
2000x1200 multimedia 2k screen
The .rd I made is also shaking, everything is normal in other rds, why is this the case?
I do not know. For me it looks like a hardware / graphics driver issue.
I still couldn’t solve the problem, I removed the car from the screen, not because of that, I deleted the can data, it didn’t work, then I added only the engine water temperature information, it still vibrates occasionally
This skin has triggers and actions related to brightness control. Try to delete them
Which ones are they? Can you give an example?
When I press the button, I turn some things off and turn others on, I am new to it, I usually do it by looking at the things that have been done,
only the shaking has decreased, it doesn’t disappear completely? I set the resolution to 2000x1200, I also edit the multimedia so that the edges are not empty and move everything to the edges, I wonder if this is due to the resolution.
