So that I don’t write to the section, it doesn’t work. I need to show the gauge before loading the skin. If I do this with a trigger at the 0-th second - my eye still manages to see the flicker.
I’m not exactly sure what you mean. Could you be more specific?
The line of code from the screenshot does not work! After loading the skin, gauge “main-background” has fade is 0 (it is invisible).
I had to double check. The section of the animation file is not read at all by RealDash. It must be something old that has not been supported for a long time.
The trick is that you need to save your dashboard in a state you want it to be when it boots. One way to do this is to have a temporary button to show the gauges you want, then you save your dashboard and next boot they will be visible.
