Hi Yani,
There are several serial port issue on Android 8.0
When using FTDI , the device shows up on list to select but does not work, the port works find with other apps.
I have spent lots of time ti see what is going on here and my serial ports worked sometimes and not other times.
When using Silicon lab CP2102 ( best in the market ) if it is the first items on the list then it connects and works great, but if it is NOT the first item and it is selected then one will get " Serial device ‘CP2102 USB to UART bridge controller’ is not supported" and it will not connect.
You may ask how to I make it be first item? I do this y just plugging in and out and get lucky and have it be the first item on the list. this works until the Deck goes to sleep and next time may not e the first item and then I get the not supported massage.
unfortunately in this one deck there is always a wifi serial port that I can not remove and it always shows up and most of the time it is the first item on the list,
Do you have any update on this? this is the only thing right now that does not work on my dash. only the CP1202 work great only if it connects.
Also one issue with your realdash can mode is when sending data there is not check sum and any error checking so on uarts errors item in the screen will jump around because of incorrect data, so it will be nice to have some type of validation, I can send video of it if you want.
I did take a look but I was unable to reproduce the problem. I would need to have exactly the same hardware setup as yours to attempt to fix the problem.
I can only tell you with the solution to check in the sketch, according to the CAN protocol, when the wrong values come.
You just need to add the conditions via the “if” operator. Then this effect will not be, incorrect data …
This happens when sending data to realdash. data is correct. but since there is no check sun on the packet and if anything lost due to Android driver then bytes will be in wrong place and will cause jump in some date.
I solved this problem by checking the addresses of incoming frames in the controller code, and only by coincidence did I send to REALDASH. And he achieved a great result.
This solution: https://www.realdash.net/forum/viewtopic.php?f=3&t=132
“I solved this problem by checking the addresses of incoming frames in the controller code”
Not sure what you mean by controller code? is this on realdash side XML file?
I have two dash one work prefect all the time, ( same data) the other depending on the USB to serial device.
USB to serial should be having any errors, it is just bad driver on Android side.
Frame info is correct most of the time the content is no correct all the time, it is transmitted correctly just no received by RD correctly.
The issue above is on Arduino, I am not using Arduino, I have my own hardware and my own OS.
The issue is only on this dash with Android 8, my side is solid and work with windows and my phone fine and my other dash.
I used the same USB to serial on other device and did not see this it it worked weather was in first place or other locations in the list. but his was also Androids 6
The issue may be with this one deck that I have, but really do not know how to solve it. ( this is Androids 8)
