at the moment, the function of tracking and resetting the service interval for the mileage of the car is working well.
I ask you to add the function of tracking the service interval by engine hours.
when you press the reset service interval button, reset both the mileage and the operating hours of the interval at the same time.
Faced with such a problem, I have one button assigned to reset A and the service interval, how do I make sure that the service interval is reset with a delay of 5 seconds?
No matter what I do, it doesn’t work, I chose dummy timer 01, I waited 3 seconds by choosing to reset the service, and anyway the reset happens instantly, if it doesn’t bother you, write an example, I will be very grateful
It’s just that I have a set button on the switch, now when I press set, I reset trip A, I want to add that when holding set for 5 seconds, the service interval is reset. But it doesn’t work out
The above instructions should get you there. Although in button use ‘Hold Value’ action, so Dummy 01 is held to 1 when button is down and set to 0 when button is released.
