I’m struggling setting the odometer. From what I understand my car stores the odometer reading in the instrument cluster and the ecu increments the cluster reading as the card is driven.
I want to set the odometer to the cars mileage then I’m guessing real dash can increment the mileage from there
I tried sending 75415.46km to ID 310 in my can xml which works but then it goes back to 0 when I remove that line from my xml.
I tried doing a button and sending value 75415 to dummy 02 then in input mapping I had odometer set off of dummy 02, that also works but then also goes back to 0
What is the difference between odometer / Car electronics and odometer calculated?
I also see something about 2103 from the odb possibly being an odometer reading, I also tried an odb xml sending 2103 to 310, I get nothing from that. 2103 reads 7x2111 when I query it from the odb2 monitor.
How do I get the odometer caught up to the cars milage?
I’m on Android 9, I did an update this morning.
If I goto Garage → top tool bar → mileage set the mileage and go back to the dash the mileage is there.
If I goto Garage - Adapters → back to dash Mileage is back to 0
