Hello!
Im using Bavarian Powerhouse desing on my 2005 Focus mk2 (2.0 diesel)
And I cant set up properly the fuel category(im beginner)
everything else works perfectly fine.
Thanks!
Assuming you are connected with OBD2 connection, check all your engine settings in Garage.
- Go to the Garage and tap the settings name bar and update all settings.
- Tap the vehicle hood and update all settings.
It is still not showing properly.
The maximum distance on full tank is 48 kilometres
Check what your ‘Fuel Consumption L/100km’ is showing while driving. If it is wrong, adjust the ‘Fuel Consumption correction factor’ in Garage until it shows close to correct.
After that, reset the Trip A to reset fuel consumption history.
