I have the CAN Bus signal for the instant fuel consumption of my Toyota. I created two Text gauges. 1) Toyota Fuel Use which I then mapped to the Fuel Consumption (Instant) Var. When I created a second Text gauges to display the Fuel Consumption (Instant) it is always 0.
Is the the Fuel Consumption (Instant) something I can define from data given by the truck or is it calculated from Gear, Engine Settings in the RealDash Garage?
Also using my Instant Fuel Consumption, I am able to calculate instant MPG. Is there a way to define a rolling avg of my instant MPG? For instance set an array of 500 values. Every second write a new value to the array, and display the Avg of the array to have an Avg MPG. (Once you get to the end of the array just start over at postion 1 rewriting over the old data)
