Hi,
I have current Triggers to show/hide Gauges based on Manifold Gauge Pressure;
Data is coming from a CAN Analyzer via a Link G4+ ECU
Current configuration:
if the Manifold Gauge Pressure is less than 1 - Hide Gauge
if the Manifold Gauge Pressure is greater than 1 - Show Gauge
This seems to work on occasion… however the trigger behavior isn’t consistent, to the point that the triggers reset sometimes, but not always…
This results in the positive (above zero) gauge being displayed sometimes - but not always…
However if i re-import the dash entirely - the issue is resolved temporarily, then sporadically breaks functionality again
Is it best practice to show/hide objects like this via an input - Manifold Pressure, etc?
Or is it recommended to rotate a Dummy value based on Manifold Pressure - and then and show/hide objects based on the Dummy value instead (similar to the Animation Example)?
Example:
if the Manifold Gauge Pressure is less than 1 - rotate Dummy 01 down
if the Manifold Gauge Pressure is greater than 1 - rotate Dummy 01 up
then
if Dummy 01 equals 0 - Hide Gauge
if Dummy 01 equals 1 - Show Gauge
