Hi.There is such an action as “click a button”. If I create a condition for example: "if ignition on =1. And I will create a reset condition: if IGN on = 0. and assign the action “press button”, then when the ignition is turned on, the button will not be pressed. and the button action will not be executed. Can you check it out?
Thank you for reporting. I found this issue and its fixed for next release.
