Hi! I have just discovered this software… Brilliant… I am in the process of designing a dash for my w123 Mercedes. I have uploaded a png of the speedometer and put a needle on it and set the speed range from 0-230km/h has per the speedo. It is always sitting at 10kmh lower than it should be in the image… Is there any way of applying an offset or do I need to redesign the needle to sit at 0 to start with?
I think you need to adjust the start and sweep angles of your gauge.
- In edit mode, select your gauge
- Go to Look’n Feel->Special->Autoscaling
- Adjust Start angle and sweep angle to match your gauge background
Tip: you can adjust values in Look’n Feel just by dragging on top of the gauge preview.
