Hello.
I was looking for why Realdash did not receive VSS information in Realdash by Serial 03 by Speeduino.
Monitoring by the Hterm serial monitor I saw that speeduino was sending 75 bytes by command A.
The VSS information is in byte 100 and 101.
I corrected the code to send all 123 bytes of information.
But despite the information appearing in Hterm, Realdash did not show the VSS, I believe it was mapped in Realdash by an old version of the code.
The data sent are these up to line 346:
else if (cmd == 0x32)
CANSerial.write("n"); // confirm command type
CANSerial.write(cmd); // send command type , 0x32 (dec50) is ascii '0'
CANSerial.write(NEW_CAN_PACKET_SIZE); // send the packet size the receiving device should expect.
#endif
currentStatus.spark ^= (-currentStatus.hasSync ^ currentStatus.spark) & (1U << BIT_SPARK_SYNC); //Set the sync bit of the Spark variable to match the hasSync variable
#if defined(CANSerial_AVAILABLE)
byte fullStatus[NEW_CAN_PACKET_SIZE]; // this must be set to the maximum number of data fullstatus must read in
fullStatus[0] = currentStatus.secl; //secl is simply a counter that increments each second. Used to track unexpected resets (Which will reset this count to 0)
fullStatus[1] = currentStatus.status1; //status1 Bitfield, inj1Status(0), inj2Status(1), inj3Status(2), inj4Status(3), DFCOOn(4), boostCutFuel(5), toothLog1Ready(6), toothLog2Ready(7)
fullStatus[2] = currentStatus.engine; //Engine Status Bitfield, running(0), crank(1), ase(2), warmup(3), tpsaccaen(4), tpsacden(5), mapaccaen(6), mapaccden(7)
fullStatus[3] = (byte)div100(currentStatus.dwell); //Dwell in ms * 10
fullStatus[4] = lowByte(currentStatus.MAP); //2 bytes for MAP
fullStatus[5] = highByte(currentStatus.MAP);
fullStatus[6] = (byte)(currentStatus.IAT + CALIBRATION_TEMPERATURE_OFFSET); //mat
fullStatus[7] = (byte)(currentStatus.coolant + CALIBRATION_TEMPERATURE_OFFSET); //Coolant ADC
fullStatus[8] = currentStatus.batCorrection; //Battery voltage correction (%)
Tks.
I think the Serial 03 is hardcoded into RealDash. Where could I find info on what is current Serial 03 datastream?
The data sequence follows the order of line 210 to 346, it has not yet been updated in the documentation.
