I have tried to change values of some of the dashboards that I have purchased and have gotten nowhere. How do I start from a blank slate?
I am excited about this program and would like to learn all about it.
You can change the values in edit mode. In edit mode, select the gauge that you want to change and tap “Input & Values” and adjust the range and warning and critical levels to your liking.
Some gauges are made from many different gauges which require adjusting multiple gauges.
If you want to start from scratch, in edit mode tap “File” → “New” and choose asset set that you want to use. After that start adding different gauges and map them to different inputs ![]()
Thanks for the reply. I will try the New steps you suggest. I tried to edit the other in the way you suggested and got nowhere.
