Hi I am trying to figure out how to extract the steering angle from the following two-byte sequence, where:
Full Left – B0=1 B1=3D
Centre – B0=0 B1=0
Full Right – B0=0E B1=CE
Any suggestions most welcome.
Centre – B0=0 B1=0
Center is quite obvious 0
Full Left is 0x3D01 which is 15617 decimal
Full Right is 0xCE0E which is -12786 as signed decimal
CAN XML supports attribute signed=“true” to interpret value as signed.
@realdashdev I am struggling to come up with the xml for this frame 0x25 entry, can you kindly advise
My best guess with this very limited info would be:
<frame id="0x25" endianess="big">
<value targetId="229" offset="0" length="2" signed="true" conversion="V/100*2"></value> <!-- Steering wheel angle -->
</frame>
Don’t know amount of degrees your steering wheel on full turns, but you can play with conversion to get it match actual degrees.
value targetId=“229” startbit=“3” bitcount=“12” units=“deg” endianess=“big” signed=“true” rangeMin=“-500” rangeMax=“500” conversion=“V*1.5”></value
I ended up honing in on this 2-bit value, which at centre is 0, and turning left increments positively from 1, but turning right decrements negatively from 767, not sure how I can get this to show as -1 onwards?
What was wrong with my proposal?
Yours does exactly the same, except it increments from 1 turning left and decrements from 82 turning right. I believe only 12-bits are used, hence mine eliminated the unused bits.
Discarding first two bits only degrades the precision of the value. I think you are in wrong track.
I am eliminating 4 bits, which if I look at some of the Toyota DBC’s I have found suggest these bits are used for something else, SSA below is the 12 bit steering angle
BO_ 37 STR1S01: 8 CGW
SG_ STS3 : 7|1@0+ (1,0) [0|0] “” AFS,BSR,DS1,FCM,MAV
SG_ STS2 : 6|1@0+ (1,0) [0|0] “” AFS,DS1,FCM,KSS,MAV,SCS
SG_ STS1 : 5|1@0+ (1,0) [0|0] “” AFS,BSR,DS1,FCM,KSS,MAV,SCS
SG_ STS0 : 4|1@0+ (1,0) [0|0] “” Vector__XXX
SG_ SSA : 3|12@0- (1.5,0) [0|0] “deg” AFS,BSR,DS1,FCM,KSS,MAV,SCS
I don’t think signed=“true” does anything when you are working on individual bits. You’d be better to read the full 2 bytes as signed, then mask and bitshift as needed on ‘conversion’.
value targetId=“229” offset=“0” length=“2” signed=“true” conversion=“V<<2”
I believe this would in effect centre the 12-bit value within the 2 bytes, but not sure how to mask?
As I understand you’d like to lose 3 least significant bits, so conversion would be:
conversion="(V>>3) & 0xfff"
I am attaching screenshot of bits needed, this is the 4 most significant bits I need to mask?
If it really is like that, you need to take second byte and bitwise or the 4 LSB from the first byte:
conversion="B1 | ((B0 & 0xf) << 8)"
Hello. Help with XML.
What kind of help would you require?
Hello. Help with the XML setup . Code from kanbus to come 00000191: 02 00 00 00 00 00 00 00. The panel does not see the signal .
<frame id="0xF191">
<value targetId="93" offset="0" length="1" conversion="V" ></value> <!-- Button 1 Dummy 01 -->
<value targetId="94" offset="1" length="1" conversion="V" ></value> <!-- Button 2 Dummy 02 -->
<value name="OilpresU" offset="3" length="1" conversion="V" ></value>
<value name="Brake_Fluid" offset="2" length="1" conversion="V" ></value>
<value targetId="178" offset="2" length="1" conversion="V" ></value> <!-- Brake Fluid Level -->
<value name="FrontFogLightU" offset="4" length="1" conversion="v" ></value>
<value name="GasBenzU" offset="5" length="1" conversion="v" ></value>
<value name="WaterLevelU" offset="4" length="1" conversion="v" ></value>
<value name="CNT" offset="7" length="1" conversion="v" ></value>
</frame>
line. WetetLeveIU , which is needed.
Could be the F in the frame id? Surely this should just be “0x191”
Inspired by @Cl_eav posting on this subject, I finally got around to resolving the steering angle for my Toyota FJ with following entries:
<value targetId="93" offset="0" length="1" signed="true" conversion="(V>>3)*2-1"></value>
<!--Comment = Steering Wheel Direction (Dummy 01) -1 = straight / left counterclockwise and 1 = right clockwise-->
<value targetId="229" offset="0" length="2" units="deg" signed="true" conversion="180*(ID93) + 180 - (V & 4095) * 0.087891"></value>
<!--Comment = Steering Angle (-30 degrees to + 30 degrees)-->
This gives -30 degrees for full left and +30 degrees for full right
