Can you add Sunlight Sensor as a Target ID.
What would be the units, 0-100% maybe?
I would assume, although when I used the “interior temp” target ID to test, it seemed like the more sun light, the lower the number was. So it’s definitely not and on/off but maybe its going off resistance or capacitance… I’m not sure.
I tested this morning as the sun was coming up it showed “27”. when I put my finger over the sensor it jumped up to 80-85. So maybe its reverse percentage? I’m not sure how that would be implemented
Ok, I will make it in range of 0-100.
