Tank Inhalt anzeigen
Hello,
Unfortunately, I don’t know how to display the fuel level.
I have installed a Chevrolet Matiz engine.
I have connected the control unit (Sirius D32) using an ELM327 Bluetooth (K-Line) adapter.
I can display everything else, but unfortunately not the fuel level.
Is there a guide on how I could get this working?
With OBD-link connections, you can read the fuel tank level based on your vehicle’s XML configuration.
Thanks for…
Who is the vehicle’s XML configuration find it?
The following steps are important.
– First, check the supported devices to select the type you wish to use.
https://realdash.net/manuals/supported_can_lin_analyzers.php
– Secondly, you should review the following page to understand how to use it.
– You might find an XML file for your car, ready for use, on the next page.
https://github.com/janimm/RealDash-extras/tree/master/RealDash-CAN/XML-files
– I hope you found my answer helpful at this initial stage.
One final note: if you do not find the file for your specific car, you can proceed to the next stage. There—and by utilizing the information gathered in the first stage—you can have your car’s file created with the assistance of the professional specialists on this forum. You will find quick and easy answers to any inquiries you may have. With my sincere appreciation.
With OBD2 connection, this is a hit & miss as many vehicles use custom PID for the fuel level. See some discussion about this:
https://forum.realdash.net/t/obd2-indicators-fuel-level-and-gear/
