Possible bug, or am I wrong?
Frame 0x208 returns. 02, 62, 6D, 1E, 1E, 00, 2D. Right Turn signal on
01, 62, 6D, 1E, 1E, 00, 2D. Left Turn Signal on
00, 62, 6D, 1E, 1E, 00, 2D. All off
This code works….Using Custom Names
<frame id="0x208" endianess="big">
<value name="TEST LEFT" units="bits" offset="0" length="1" > </value> <!-- Left Turn -->
<value name="TEST RIGHT" units="bits" offset="0" length="1" conversion="V>>1"> </value> <!-- Right Turn -->
</frame>
This one does not … When using target IDs
<value targetid="160" units="bits" offset="0" length="1" > </value> <!-- Left Turn -->
<value targetid="161" units="bits" offset="0" length="1" conversion="V>>1"> </value> <!-- Right Turn -->
</frame>
I am also having the same problem with Speed ,in another frame… Custom Name will work, Target ID does not
