Target IDs appendings
Front Left Wheel Speed, Front Right Wheel Speed, Rear Left Wheel Speed, Rear Right Wheel Speed
Also, Daytime Running Lights (On/Off), Accelerator Pedal Pressure, and Blower Motor level.
bump just in case this got lost in the posts
Heater motor (we’re from Finland) level, id 172
Daytime running lights - same as parking lights.
Accelerator Pedal Pressure - Does acc pedals have pressure sensors? Sounds like a good canditate for custom input.
independent wheel speed sensors; These would conflict with existing inputs, like Vehicle Speed, Transmission VSS, VSS1, VSS2…
I think Accelerator Pressure is variable. The number changes much more if I adjust my throttle controller to Race, from Normal or ECO. So yea, perhaps a custom input.
I made my own debug button to check stuff and its just more convenient to have the stuff that actually works on one page versus the stuff I’m testing on the Custom page.
As far as Daytime Running Lights. Mine are separate from parking lights. Perhaps a better name would be “Automatic Daytime Running Lights”. My stalk is Off, DRL(Auto, parking, headlights. Also foglights on the stalk as a separate switch. Hitting highbeam will keep lowbeams on but turn off fog lights. But, any of these sets the Daytime running light startbit to 0
Maybe I’ll throw in DRL, ok?
:grin: okay hehehe. Thank you
