Can you help me? I’ve started having a problem with the temperature reading; it’s getting stuck. I noticed this wasn’t happening in previous versions. I configured it via the custom map, but the problem persists. I created a text gauge for the temperature to monitor it, and it’s clearly stuck.
Help with temperature calibration.
https://youtube.com/shorts/xNuxvy7on00?is=SiRBNqwMcWZRJpFE
I’m having a problem with my vehicle’s temperature reading; yesterday, the data got stuck, even when using an OBD2 scanner.
If the temperature reading looks wrong, I’d first compare it with the actual coolant temperature from the car’s ECU or another gauge. If those don’t match, check the selected PID/sensor and make sure the unit is set correctly. A bad sensor or incorrect PID can easily cause strange readings.
