Hi everyone. My Hansshow Screen does have access to my OBD2 port but the main screen is boring and can’t customize. I can however download Realdash but I need help if it’s even possible to have the Realdash app be fed information from the hansshow device without the need of an OBD2 dongle. Thanks!
It is possible to tap into CAN bus of the Tesla and read absolutely everything. We are working on some kind of a generic Tesla XML, but it is a lot of work as there are literally hundreds, if not thousands of values available on the bus.
Thanks! Def something to consider but the other thing I want to know is how to setup this device with Realdash? This is. Essentially an Android tablet with it’s own OBD2 integrated and connected to my port so essentially I need to feed the info to the tablet directly without a Bluetooth OBD2 dongle
We would need to contact the manufacturer if vehicle connection has a API that other apps can connect to. In case of typical Android headunits with build-in CAN, there is no API for 3rd party apps to access the vehicle data.
