The Text Gauge / Look & Feel / Transformations / Rotate doesn’t seem to be working correctly.
For the first gauge I added, it is always setting the value to 136 and doesn’t save the value. It does show the text at (what I’m assuming) is 136* though.
On the second and third gauge I added, it is always setting the value to 0.
I also tried adding a Needle Gauge, and it also isn’t saving anything but 0.
Edit. It looks like I can get it to work if I change the angle value, then toggle the rotate a few times.
