The problem with choosing the sensor source by obd
Hello everyone, I need help For some reason when connecting the obd elm327 does not see fuel consumption, boost, maf,there is no choice, although when choosing the protocol it shows that it is.
Any thoughts on how to find fuel consumption by odb elm32?
Check Engine/ECU Inputs. Not everything will show up when you search by OBD2. They should be in the first category.
The panel from obd2 used to work, speed, rpm, fuel level, fuel consumption worked, now I can’t find a way to select a source
By chance did you change the protocol used by OBD2?
Garage β†’ Connections β†’ OBD2 protocol set to automatic
I changed it, on automatic, the same thing does not see the RPM, speed, etc., and interestingly, it worked before
No changes to input mapping?
You can always try removing the Bluetooth device from the app and pairing it again.
Everything worked before what you did in the picture?
