Hi, I’m using a MS3Pro ECU and plan on using this TPMS system.
https://www.youtube.com/watch?v=S0TlRkNWheQ
I’m wanting to be able to display Tire Temperature and pressure in a similar manner using RealDash in a graphical representation. Each sensor has 16 channels of IR Temperature and there would be a total of 4 sensors used. In addition to the 16 channels of IR Temperature there would also be a tire pressure sensor as well.
I will be interfacing this data with the MS3Pro with the help of the ECU manufacturer. It should be straight forward in their opinion as it uses CAN Bus Protocol. I will have a USB connection from the ECU to a SBC running android for RealDash in my 1967 Mustang. Thanks!
