Touch keyboard doesn’t popup in Realdash but TK. works in other apps.
Not sure its a bug or it could be windows related.
Thanks for reporting, will check.
The same problem on Android. It seems this problem has been dragging on since the v230 version.
RealDash will not show the virtual keyboard if Android reports a physical keyboard being connected. Some USB devices, like Mice etc unfortunately actually report to OS on some cases that there is a “Physical Input Device” present which is interpreted as Keyboard by OS. This does not happen on all Android versions.
Really! I returned to the old mouse and everything worked again. Is it possible to create a permanent on-screen keyboard dropout point in the settings for such cases?
This could be a last resort. I’m not keen on adding new options as there are quite many already ![]()
