Trigger storage of snapshot value into a Dummy variable
I would like to know if it is possible to trigger the storage of a canbus value (snapshot) into a dummy variable, where this dummy variable is also included in the conversion calculation for another canbus value?
I don’t see why not. Only way to know is to try.
Thanks @realdashdev, can you suggest which action I should use for this?
@realdashdev no need to respond, I used Set Value (formula) action using two dummy variables, one to capture the value I want, and the other to receive the value / incorporate in the xml canbus file formula, this works fine
