Triggers do not send button actions
Hi Yani,
it look like the tiggers will not act on action that will send data out in readlCan mode.
like using a triggers to turn Hazard lights on, this should work same as if the button function.
Mostafa
Any update on this?
I’m unable to reproduce this. CAN write values seem to go thru same trigger checks as all the rest.
I will check again,
Action I have is button press and the button is set to Hold mode, so should send 1 when first triggered and once release should send a 0. did you test this type of button?
Thanks much.
