I have not received any other report of this problem on the latest version. Do you have an option to uninstall/reinstall to see if that fixes the problem?
I could uninstall/reinstall, but I did all the settings to match my needs in the car, that it will be such a waste of time redoing all… I’m sorry
The trip was a very useful feature, but for now it’s not worth doing all that job, sorry
By the way, the latest version allows you to just kill the power and is still able to restore saved state on next boot. I also use RealDash on Joying Android autoradio daily and it works very well.
I will give some try and eventually let you know any news, thanks a lot.
Anyway, just because you mentioned you are using in an autoradio too, have you found any method to have Realdash run automatically every time you start the car? I have tried any option in the app, and any type of event with other app like MacroDroid and similar, but with no result
I have it fully implemented!
In addition, there are several ways to do this!
It is enough that the RD would hang in the “background”.
And it is called instantly by the events of the ignition key!
This is implemented via Arduino for $ 5! Cheaper than ELM327!
