I am just getting started with RealDash. I have successfully connected CAN and can see some values changing based on my input. However, I am trying to modify the example animation file to change calculations and when I try to import the animation file into RealDash, it just gives the message “failed to import file”.
I have tried all of the methods below. It must be something fundamental I am missing.
- Clone the repository to your computer with Git and then copy the file to your device.
- Download the entire repository as zip file from GitHub, unzip, and then copy the file.
- Open the XML file in GitHub and use ‘Copy Raw Contents’ button and paste them to a text file.
Is there some additional permissions I need to set on the file or in Android to enable editing of xml files?
I am running RealDash on an Odroid M2 with Android 13 and a 12.3" ultra wide screen.
Regards,
Stephen
