Unable to import or save edited dash layouts
We do not store old APK versions. Some people find them from Internet.
Save option writes the file to the same place where its loaded from. If that is not possible (read only folder), the Save as option is shown instead.
2.6.8 update seems to have fixed this issue for everyone else but you. What is different on your setup, I do not know. You can help us:
I can´t “Save as” a modified dashboard with a new name. This does not happen when I use the same dashboard name both by pressing the “DONE” button or “Save” option. If you need a more detailed description, please let me know which details you need.
In the following video I move the speed limit to the right and try to “Save as”:
Screenrecorder-2026-08-19-19-41-28-708
Regarding the debug log, I have read the instructions in the link, but when I edit my dashboards I do it at home, and I am not connected to the can adapter: Do you think that is really needed?
Yes, debug log would be very helpful.
Hello again.
In order to simplify the problem as much as possible, I send you a new video of a dashboard with only one parameter (vehicle speed). I have also sent you an email with the debug log and XML file.
As you can see, when I modify the “X” coordinate of the speed, I can save the RD file with the same name (overwrite with DONE option), but when I modify the coordinate to the initial value and try to “Save as” the RD file with a different name, I get the message “Save file… Check file location”.
Screenrecorder-2026-08-30-18-26-55-84
I hope you can help.
I have downgraded to v266 and it works for me.
