When using text guages to display units that automatically change when the RealDash setting is changed, the units will not update while the app is running if it is inside a container. It does work on startup, but only on startup. If I remove the guage from the container it updates as expected with the RealDash Settings selection.
Example where one text guage is removed from a container, while the other two are still within the container.
