I use a custom description file CAN
The first time did not work. Created a file again, uploaded to realdash.
Everything is fine, but the data from the previous file also remained in the program. Can I delete the old settings?
Clear application data in the app menu. Be careful, erase all the settings you entered. Or reinstall. The result is the same)
this is the simplest but inconvenient solution
From 1.6.6 there is a UI to do this:
- Go to settings->Units & values->5th page.
Thanks!
