Video Gauge continues to loop audio after video playback has finished (AndroidOS)
Hi there,
I’ve set up a video gauge with a basic trigger to play when the throttle position exceeds 90%. When I test it on my Windows PC using simulation mode, it works perfectly. The video plays once when it’s supposed to, then stops. However when I run the same thing with the same trigger on my Android head unit in the car, the audio from the video continues to loop after the video has ended. It does not stop.
Worth mentioning:
  • The video gauge is NOT set to loop.
  • The trigger has a 30 second cooldown and a <50% throttle reset point.
  • I have tried creating a second trigger to “Stop” or “Reset” video gauge playback after 3 seconds, neither have any affect on the looping audio.
Does anyone have any ideas for where I might’ve gone wrong? or is this a bug on the Android version of RealDash?
Thank you!
Thank you for reporting this. Just to clarify, video playback stops as expected, only the audio is left looping?
Correct, the video only plays once as intended. However the audio from said video continues to loop on it’s own.
I found this issue. Will be fixed on next release.
