Hi,
How do I change the colour of a sweep gauge based on a calculated trigger or dummy variable?
The warnings and limits paramters only allow me to use values to set limits.
Application:
I have a needle for Actual AF and arc sweep for Target AF.
If the tune is good the AF needle moves closely to the target arc sweep.
If the tune is off I want the arc sweep to change colour to orange or red.
I assume I can set up global triggers to a dummy variable like follows
Normal - if ABS(Actual AF - Target AF) < 0.25 → Green Arc Sweep
Warning - if ABS(Actual AF - Target AF) > 0.25 and <0.5 → Orange arc sweep
Critical - if ABS(Actual AF - Target AF) > 0.5 → Red arc sweep
I just need to assign that to the arc sweep colour somehow.
I may also need some sort of smoothing of this too as A/F tends to be a bit jittery.
