Waveshare not connecting to VW MK5
I’m newbie to connecting things to my car.
previously , I have posted a topic to connect OBD to my realdash but sadly OBD doesnt send all info to realdash such as ( Odometer , Fuel level , Tempreture.. etc) so I planned to buy a compatible USB CAN ( Waveshre ) to receive all information.
I bought this one and connected it to the High and Low Can cable. I can see the dongle blinking RXD which means its receiving Data. but still nothing shows up in the monitor.
kindly help…
Your adapter does not seem to be a CAN adapter. It converts USB to RS485 serial, which (to my understanding) is a different thing.
See supported CAN adapters here:
My bad. As i said im newbie.
I will order the correct one and update you.
Thank you sir
I got the new one ( CAN to USB) but after i connect it to HiCan and LowCan, the RXD isnt blinking. And i dont see any Data on the monitor.
I have set the correct Values baud rate is set to 2000000 and also tried 1228800 and still nothing shows.
Any help?
Sounds like a wiring issue. You need to ask someone to help you to measure that your vehicle CAN H and CAN L wires actually have some activity, and to verify the resistance of the CAN bus.
