Is this possible?
Triggers and actions will be either included in dashboard (.rd) file, or in garage settings (global triggers and actions), which both can be uploaded to MRD.
ok, thanks, good to have you back from vacation.
I’m not sure if I’m expecting too much from MRD sync.
I would ideally like to have the option to edit dashes and change any settings etc on Windows and following a sync on the in car android unit everything is reflected as per the windows instance exactly.
You can do that, but you have to manually upload/download the dash/settings files.
