Trying to make show and hide gauges actions.
There is memory 1 & 2 and mode buttons in multifunction stalk.
It send can-frames with RealDash-can xml.
In trigger condition input is Steering Wheel 1 for mode button, Steering Wheel 2 is for memory.
All works well in Windows when press numbers 1 or 2, but in car setup only Steering Wheel 2 is doing something.
I changed wires in Arduino pins so that mode has Steering Wheel 2 and memory has Steering Wheel 1, then mode works but no memory.
I deleted all triggers and actions and made new two triggers. Just for hiding and showing one gauge for test.
Modified xml. every time for correct target ids.
I tried Steering Wheel 1, 2, 3 and 4 in trigger condition source inputs.
1, 3 and 4 does not work with any buttons in stalk.
Again it work only with Steering Wheel 2 and with both stalk buttons.
Yes it is difficult to advice remotely, but there should be nothing what stops these others work.
