Set - ignore animation and you will not have this item enabled the next time you start.
The same with any settings.
Whatever you configure in the settings - it will not be saved …
I’m unable to reproduce problem not saving the settings. And I don’t think there is a ‘ignore animation’ setting anywhere in RealDash?
“ignore boot animation”
“confirm on exit”
“skip splash screen”
“ask when deleting”
Section - settings.
The aspect ratio is also not preserved …
Please send me your exported settings and I will check if this has something to do with that. After that, try to uninstall-install to check that save works on default profile.
Only thing that I can think of is that there is something wrong with your profile that may cause save to fail.
