Write-up for how to fullscreen RD with Ubuntu 24.04 on boot
I had some issues with RD only opening in windowed fullscreen on startup.
This fix is currently working for me. wayland was most of the issue..
Step 1: Switch to X11
Check Current Session
Run:
bash
CopyEdit
echo $XDG_SESSION_TYPE
If it says wayland, continue below.
Switch to X11 (GUI Method)
  1. Log out of your Ubuntu session.
  2. At the login screen (GDM), click your username.
  3. Before entering your password:
  • Click the gear icon :gear: in the lower-right corner.
  • Select “Ubuntu on Xorg” (this is X11).
  1. Log in.
Verify
Open a terminal and confirm:
bash
CopyEdit
It should now say x11.
Step 2: Install xdotool
bash
CopyEdit
sudo apt install xdotool
Step 3: Script to Launch RealDash and Toggle Fullscreen
bash
CopyEdit
#!/usr/bin/env bash
# Start RealDash
realdash &
# Wait for the window to appear
sleep 5
# Get window ID (adjust title match if needed)
WIN_ID=$(xdotool search --name "RealDash" | head -n 1)
# Focus the window
xdotool windowactivate "$WIN_ID"
# Send Super+F4
xdotool key Super_L+F4
Save as:
bash
CopyEdit
nano ~/realdash_fullscreen.sh
Then:
bash
CopyEdit
chmod +x ~/realdash_fullscreen.sh
Step 4 (Optional): Run Script on Login
To auto-run the script after login:
  1. Open Startup Applications (gnome-session-properties)
  2. Click Add
  • Name: RealDash Fullscreen
  • Command: /home/YOURUSERNAME/realdash_fullscreen.sh
  • Comment: Launch and fullscreen RealDash
  1. Click Add and close
You’re Done
  • Launch automatically
  • Be focused
  • Go fullscreen via Super + F4
Thank you for sharing this information :+1:
