XML file Renault Dacia 1.5 dci k9k
Hi everyone,
I’m looking for a XML Renault/Dacia 1.5 dCi K9K engine with dpf, specifically for a 2013 Dacia Lodgy 1.5 dCi 110.
I’m not very technical, so I’m looking for a ready-to-use XML file.
I’m using RealDash with an canable rh-02 usb interface on Android.
I connected it, but is stuck on “Connecting” when on a dashboard, although on monitor it shows frames like "000022: ff ff ff … .
I know there is a simpler solution, I was going to buy an iCar Pro 2S, but I would like to have the data displayed in real time.
I found that k9k_pids/common_with_DPF at master · MeganeClubUkraine/k9k_pids · GitHub
Can it be useful for my case ?
Thanks in advance!
Hi,
I’m still looking for a working RealDash XML file for a Renault/Dacia K9K 1.5 dCi with DPF.
If anyone has one, even from another Renault/Dacia model with a K9K engine, I would really appreciate it.
Thanks!
Does anyone have an XML file for the K9K engine, or could someone help me create one ?
The thing is, the data isn’t needed for the engine itself, but rather for the ECU (Siemens, Bosch, etc.).
For example, I have a Renault Megane 2 1.5 dCi,
and the ECU is a SID 304 (ECM / Injection) – K9K step 2 FAP.
Hi Difas,
Sorry for the late reply. I’ve attached a RealDash file for your K9K with DPF, based on the PID list you found on GitHub.
How to use it:
  1. In RealDash, open the connection settings for your CANable adapter.
  2. Set the CAN speed to 500 kbit/s. The ff ff ff frames you saw usually mean the speed is wrong.
  3. Choose the attached file as the CAN description file.
  4. Turn the ignition on (or start the engine) and open a dashboard.
What you should see: boost, rail pressure, temperatures, and DPF info like soot mass, DPF pressure, and km since the last regeneration. Look for them under “ECU Specific” in the input list.
Please note: this file hasn’t been tested. If some values stay empty or look wrong, tell us which ones. A screenshot from the CAN monitor would help a lot too.
realdash_can_renault_k9k_dpf.xml (11.7 KB)
