Good day!
I would like to propose a feature which would help users with more or less advanced ECU’s.
I, however, would take an electric motor with a traction inverter as an example, because I work with that.
The inverter is capable of sending a lot via CAN. Currents, voltages, temperature, motor speed, whatever you want and need.
It is also possible to send torque and motor speed, which would allow a very cool feature.
A graph, with adjustable X and Y axes, selectable inputs for X and Y… and then an adjustable (for example - red ) dot as a pointer of the current X-Y-value… and adjustable background.
So, I would take RPM on the X-axis and Torque on the Y-axis, take a graph of maximum torque of my electic motor as background, and then I would be able to see, in which point the motor operates!
I know that relatively advanced diesel engines can output torque estimate as well.
But because of versatility, this would be able to help with many possible X-Y-maps.
Kind regards,
Evgeniy
