2007 dodge charger rt canbus xlm helpppp please
I do not understand what you mean by 1st set or 2nd.
The left portion of the CAN monitor shows the incoming CAN frames.
The right portion allows you to filter displayed values, and shows the decimal and binary value of the selected byte(s).
So the right portion is rhe numbers i would copy to start making a xlm file ?
So all these numbers i copying r wrong one ?
I think you need to find a friend or someone local that can help you understand the CAN messages and related XML file generation.
Is there n e way u could make a tutorial video on how to make a xml file i can not find a proper one the one i found is not in English or point me in the right direction
Based on your spreadsheet please give this a try, I can’t see from this where your brake signal is without knowing the not activated brake frame
other.xml (1.1 KB)
