After last update i need to reconfigure usb port
Jani,
Today after updating to 2.3.7 , i start to have issue regarding port number. I must open garage and select realdash can and change the port number to start communicate with Aduino.
Can you please check ?
Regards
2.3.7 has an improved support for multiple simultaneous USB devices on Android. Send me a debug log:
Hi Jani,
I have sent 3 debug files. Size around 110 k.
Also, i have sent another one after configure the usb port so it can communicate with arduino.
Regards
I see what the problem is. After the update, the USB device name must have a match when attempting to connect. You have ‘unnamed’ USB device, identified by its internal link, like:
/dev/bus/usb/004/010
Problem with this name is that this link may change over the reboots when USB device hardware is allocated. You have a device with name /dev/bus/usb/004/010, and next boot name may be /dev/bus/usb/004/011, hence the device is not found when attempting to connect.
We could add a failsafe, that device is selected by VID/PID if name does not match, but this will introduce another problem; when using multiple USB devices of same type.
Thanks Jani,
Could i go back to previous version? It doesn’t have this issue.
Regards
We do not store old versions. I can build you a test version instead. Send me an email to contact@realdash.net for a download link.
