APP CRASHES when switch song
When I use Google Music or YouTube Music to play music, the app crashes and closes every time I switch songs. I’m also wondering if the DASH zoom settings are saved because every time I open the app, they revert to their original settings.
I sent a debug
Thank you for reporting. We found this issue and fix will be in next release.
Thank you, There are more serious problems.The connection between Rd and ODBC adapter keeps disconnecting these days.It disconnects within seconds,It is very stable in the torque app.The strange thing is that after I turned on torque, I could connect stably again after returning to rd.
OBD2 or OBDC?
I only ask as I’m unaware of a different device.
If it’s a typo and OBD2 this would be device specific most likely. I use RealDash daily for hours at a time. On top of that I use cheap OBD2 devices instead of their recommended.
Hardly ever an issue of it disconnecting.
Is it possible that your device is connecting to another app or device?
Try removing the Bluetooth device from RD and readding it.
OBDLink MX+ OBD2 ,Android reset the connection, same situation
@GO1 that’s definitely weird as those are the devices they use for testing. Any changes? Like after the last app update, did Android update? Does it stay disconnected or does it connect for a while?
Have you tried multiple request and request only first reply?
Idr exactly how these work but I know those can sometimes affect it.
You can help troubleshooting by sending a debug log:
