Autronic Serial - Windows not working but Pi works
Hi,
I have been running my Pi Realdash for a while without any issues.
Switching to a Windows 11 SBC, I can use my USB to Serial converter with my Autronic SM2 ECUCAL software on COM4 fine.. but Realdash can’t communicate with SM2.
I have set the Autronic data source and Realdash sees the COM4 for the USB to Serail Adaptor, 9600bps. But when RD tries to connect to the SM2 data stream, all I get is the “Connecting to” popup continuously flashing and no data.
Appreciate any tips thanks.
Are you sure 9600 is the right baud rate for your ECU? Sounds pretty low.
Hi yes the Autronic SM2 is a 26 year old ECU in a 28 year old NB MX5 :slight_smile:
The data logger serial stream is 9600 and that’s how the pi5 running Realdash works with. No special DTR/RTS flags needed with the USB to serial adaptor.
Doing the same thing in W11 using an N150 CPU, my Autronic ECUCAL works fine on COM4 but Realdash doesn’t work at all on COM4. COM4 usb serial device shows up when I configure the input source in Realdash.
( I did exit ECUCAL so there’s no conflict on COM4, also rebooted and tried other baud rates)
Ive got both RPI5 and WIn11 versions running side by side.. both are set up with tty/USB0 at 9600bps and COM4 at 9600bps..
all i have to do to get it to work on the RPI is hot plug the USB.. but still no joy on Win11.. again the USB Prolific PL2302GS driver works fine with SM2 ECUCAL program.. but not with Realdash.
I’m using the Realdash WIndows Store version (latest).. is there a way I can rollback to try an older version ?
I don’t think there is any changes on Windows version serial port handling for years.
You could try to send a debug log:
