Hello guys. As the title says, i cant connect my Link G4 ecu to display data to my android tablet(huawei media T10). I bought the full version of realdash, a micro usb to usb female otg cable and the pclink usb tuning cable.any help is much appreciated.
Have you set the correct baud rate for the USB connection?
Maybe this will also help:
How to connect to Link ECU - Connectivity / Link - RealDash Forum
I have a G4 xtreme not a G4+ or G4X. But i ll give it a go…
Yea, the problem with Link ECU is that at some point they stopped sending the data stream from USB connection, but its a bit unclear of which ECUs and/or firmwares it affects. If you have an ECU that does not send USB stream, your only option is to use CAN connection instead.
Ok. I set baud rate to 38400 but and long datastream but still no connection
Which can connection will work on the ecu?
Can i connect through a link can plug?
Sure, just connect CAN H and CAN L lines from your ECU to one of the RealDash supported CAN Adapters:
I bought and tried to install robotell can adapter. I connect can H and can L to the link canf plug but
It doesn’t work. I use a huawei T3 android tablet with otg plug.
And in the can description files the only option i have is short can and generic dash stream. I m confused…
Do you see the data in CAN monitor?
