please consider the question so that you can save the custom mapping settings to a file in order to transfer the settings from the developer’s computer to the client’s dashboard. (with config xml as example or other)
I optimized the global triggers as much as possible, the triggers in the skin are busy with animation, and now the projects are very large and too much code is being created for different sensors.
One thing to note is that if you are importing garage settings that contain custom mapping for ECU Specific inputs, inputs must be imported first from XML file. Otherwise values are not found when garage settings are imported.
Im wanting to add small tune to my 99 Acura TL with J32A1 engine im having heavy foot pedal added cold ram air intake its diy custom any small air fuel map input you can help with car is running slow untill Vtec opens up
please tell me where the data is stored in the file system? i try erase this file/
at the moment, the only thing that saves me is assigning new user variables
I found a bug where it may be that Custom Mapping is off, but Custom mapping continues to work.
if you press the button again, it is like double calibration according to the old table invisible to the user and the new one.
it also seems wrong to me if you click the button, then the Custom mapping table disappears. if you then turn it on again.
