Fuel level calculated is 0
Hello,
I am trying to display the fuel level, but unfortunately without success.
I entered the fuel capacity in the “Garage” section, following the instructions exactly.
The display is set to “calculated fuel,” but after about 2–5 minutes, it resets to 0 every time.
What am I doing wrong?
try Use the forum’s search function; you will find many topics addressing the issue of calculated fuel consumption.
see that
Click here
It could be useful.
Since the fuel tank capacity and gauge aren’t working properly, I’m going to use the maintenance interval as a fuel level warning.
You can use ‘Fuel Level (calculated)’ input if you have working fuel consumption on your setup.
Only reason that I can think of is that your fuel consumption is way more than actual car. Fuel consumption multiplier can be adjusted in the Garage settings.
