G4X Ecu for v8 Impreza sti compatability
Hi, I have tried to connect my Samsung phone to the ecu for Realdash as per instructions but to no avail. Can anybody confirm if this ecu will work with Realdash connection to a Samsung phone via usb?
Yes but not VIA a usb. You’ll need a WiCan wifi adaptor and to connect that to the ecus CANBUS. Then you’ll have to set up the streams in the ecu.
USB connection should also work just fine on Samsung phones. Use a high quality USB-OTG adapter and make sure that you have given permission for RealDash to use USB.
Hi, I tried this USB and it did not work. Would this not have been good enough? Could you confirm the settings I should have done for the permission? Thanks
https://www.amazon.co.uk/Amazon-Basics-Converter-High-Speed-Certified/dp/B01GGKYXVE/ref=sr_1_1_ffob_sspa?crid=2Q679SPFMLD0E&dib=eyJ2IjoiMSJ9.O4rSbdmkKzN9ROeAnqY118ey-oVNBB5X9FSSZv1OEr0ETNsdu3ldXp6Y-Gx5ytfQUPfN6864UfimW1MfhdlkIX6rTRXtB58g-zNuBmV-0PcdfOtl2iiP_Ovd4CalwGxRDD_k-KAjnztve8pSPl34ofGEsuo9gts-8oBcmwlU2BsxtzDQx16a3JiQykAaOpq3E-xwK4bhfk99M5Wh1Una8g.wBRaog9uJ-G8L2gzD_n1ej0XEm3ugre--i22goYcYXM&dib_tag=se&keywords=usb+otg+adapter&qid=1725600930&sprefix=USB-OTG+adapter+%2Caps%2C65&sr=8-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&psc=1
