How to connect to Assetto Corsa
WINDOWS 10
Localhost connections on Windows 10
On your computer running Assetto Corsa:
  1. Find your game computer’s IP address.
  2. Open file “C:\Program Files (x86)\Steam\steamapps\common\assettocorsa\system\cfg\assetto_corsa.ini” with notepad.
  3. Find line “ENABLE_DEV_APPS=0” and change it to “ENABLE_DEV_APPS=1”
  4. Save the file.
    PS4
On PS4 in the main menu hit triangle, then settings. One of the menus it mentions UDP telemetry. Turn it on. The setting below let’s you add the ip address of your RealDash device.
On your device running RealDash:
  1. Connect to same local network with your Assetto Corsa instance.
  2. In RealDash connection settings, set your computer IP address.
  3. Assetto Corsa will send car data when the race starts.
Edit: Forum is English only. See forum rules:
Forum rules - General / RealDash Forum - RealDash Forum
