Janni recommended me a while back to start using the forum to report any issues I find within the app.
Would I need to need to create a new discussion each and every time?
Also could I just make a huge list of items or post them one at a time?
I am currently using an Android Device. I have it set to Fahrenheit and Miles.
What is the target ID for “Distance until next Service”?
Also I’m comparing “Distance until next Service” to X miles but it’s treating it as X km. I know that as I checked the value of “Distance until next Service”.
The value showed 745 miles when the trigger should’ve happened at 1200 miles. Used Google to convert 745 miles and it’s roughly 1200 km.
Could we fix that?
I think it’s been said that triggers will always use Celsius and Kilometers but I beg to differ as my triggers in Fahrenheit work with no issues.
That’s exactly what I meant, where did this value come from because it’s a calculated value and not part of the ECU, you can try to see where this value comes from ODO TRIP A TRIP B I couldn’t understand where the value was taken from
in the garage there is distance between services & hours between services don’t rely get it
You can set the distance till next service through the garage. Thats technically the maximum as when you reset it it’ll go back to that value. Then as you drive it lowers the value through its own calculations and the current value gets stored in “distance till next service”. Neither Trip A nor Trip B affect this.
This is a calculation error by the developers as I’ve ran into similar issues before. Usually I just email Jani about it.
No worries. I use the app religiously so I use to just email Jani about bugs but he told me to start using the forums to report them.
Most of the time I can either replicate the issue or find out what specifically what it is but I’m not part of the development team to edit coding let alone know how to.
So it’s treating 1200 or whatever variable I’m using to compare against as km instead of miles. That’s the calculation error.
735 miles is 1198.961 kilometers via Google so that’s how I know.
I stated with Celsius and Fahrenheit, Celsius is the main value and gets calculated into Fahrenheit. I have Fahrenheit set into the app settings and when I make triggers I can directly use Fahrenheit values.
So the same thing should apply to kilometers and miles.
At triggers please. I have app settings for Fahrenheit and Miles but in triggers it’s using km instead.
‘Distance til Next Service’ is getting pulled as miles and is shown correctly. But if I compare it to a static value like 1200, it’s treating the 1200 as km and not miles.
Ex: If ‘Distance until Next Service’ is less or equal to 1200
Trigger doesn’t perform at 1200 miles, it’s performed at 1200 kilometers.
Thank you, also I was working on my dash yesterday afternoon. Both on PC and Android if you try to copy a trigger or action it would closer the app. I have the latest android version, I don’t know which version I have on my PC.
OBD2 “number of cel codes” is always displaying 113. When I read cell codes it’s showing the correct cel code. The check engine light works correctly turning on and off with the device. But the value “number of cel codes” stays at 113 even when Bluetooth is off. I’ve adjusted both min and max value and that’s the number it stays on no matter what. Even if it’s different values or the number of cel codes change.
