Hi everyone I’m try to connect RealDash to obdii on my mini r53 but I tried connecting it’s not working but it shows on the pc and in the obdii monitor it shows up as connected but when I go on the Dash again it won’t connect any idea on troubleshooting steps thanks
the hardwhere ids USB\VID_1A86&PID_7523&REV_0264
One thing to check is ‘Settings->Data Source’ that its set to ‘Connections’.
Do you see the ‘Connecting …’ message at the bottom right of the screen when in dashboard?
thanks for the replay I have just checked yes it is set to connections and yes I do see it saying Connections in the bottom right
Send a debug log, instructions here:
How to send a debug log - General / Bugs and troubleshooting - RealDash Forum
I just sent the log to you hopefully I did it right
What OBD2 adapter is this? In the log it is just shown as ‘USB-SERIAL CH340’ which is not typical OBD2 adapter name.
I see from the logs that RealDash connects to the device, sends a command ‘atd’ and never receives any reply from the device.
Thanks for the reply back it says it an elm327 to usb I did try another OBD software and I didn’t get a reply back as well so I think it either a drive issue or the with the obd adapter
